how do i de-winterize my 40hp johnson outboard
D
DJ
Guest
Re: how do i de-winterize my 40hp johnson outboard
1. Spark plugs tight and connected?
2. Lower unit lube fresh?
3. Start it up and run it.
Vic.S
Assuming it was all fully serviced when winterised
Set it up with a water supply, in a barrel ,or on muffs if you must, and a fresh fuel supply.
Take out the plugs clean off any oil and check the gap.
Crank it a few times to expel all the fogging oil.
Replace the plugs and start it up.
When the smoke dies down check the cooling is OK
