Re: how do i determine what prop will fit my 1986 85 hp
Good on you Jerry! The title of the post gives engine information.
At any rate, if the engine is running well, a 13 X 17 or even a 13 X 19 prop should give good results. You have the option of using closed hub stock type props or thru-hub exhaust type props. Either type will give the same performance.
I would start with whatever is on the engine now or, if you can't get any numbers, a 13 X 17. Numbers can be in three places depending upon prop type: Under the prop nut, stamped into the side of the hub, or behind the hub. When you remove the prop, very often the thrust washer will have corroded into the hub and you will need to drive it out with a long screwdriver or punch. Be certain the thrust washer is replaced on the propshaft. It goes on the engine, not the boat, just as the prop does--LOL
You have the option of using stainless steel or aluminum props. Depending upon the design, you may need to use a different thrust washer. Some props, while listed for Force engine will need minor modifications to fit correctly and with some brands you will need to remove the anode--circular thing bolted with two screws. They don't tell you that.
You can use props listed for Force engines and some listed for Mercury engines as long as they fit the small gearcase Mercury.
The 86 should have an extended propshaft and flare washer/tailcone. It is not necessary to use them and if they are missing, no harm. It does look better with them though.
Rather than buy new, Personally, I would shop the auctions under Force Chrysler propellers.
