tfbrown1270
- Sep 5, 2003
- 202
I have had trouble periodically with this motor for the last few months but had not located a fault till today.
It will not start without advancing the throttle by hand (by pulling forward on the cam follower) and even then it runs poorly, missing as though on one cylinder.
Having noted that I removed the spark plug wires while running as above, and noted the engine stops when the bottom spark plug is disconnected but the top one makes no difference. I concluded that the top plug is not firing but don't know why.
I see no way to switch ignition coils to see if the problem follows the coil because the wires are not removable (or so it seems) from the coil.
Should I throw parts at it? Seems the coil is likely responsible.
Are the coils expensive? Do I replace the two together or just one?
