Ok, I've got my '86 Johnson 40 Horse completely disassembled. I need to remove the old pistons, replace the loose needle bearings, and then attach the new oversize pistons. Without buying the special OMC Tool used to remove the piston pin, what is the best way to take that pin out? I have both retaining ring/clips off, and used a screwdriver to try to drive the pin out, but only moved it about a 1/4". Thanks in advance. Tink
