Larry Baloun
- Jul 28, 2017
- 34
I have a 4.3 ltr tks 2008 mercruiser with water pouring out of the front right side frost plug which is behind the motor mount. How do you get at it and how do you replace it?
...so how do you "remove outdrive" and "realign" engine mount?
Thanks Chris, I like your videos. That alignment tool looks like it is a pretty specialized item - not sure of availability. Also do you cover re & re of outdrive anywhere?
The 5 blue drain plugs as well as the square intake manifold drain plug were all removed to drain and replaced in the fall ...so it was not full of water. I don't understand how this could happen. Given this situation how should I go forward?
