The Livewell is new to me. There are two wires that go to a arieator/livewell switch. A port from a rule livewell pump in the bilge, that goes outside the transom below the waterline. A hose that goes to the livewell. Another hose that is larger and white with a strainer on it, and apears to go out the transom above the waterline. There is a plug in the bottom of the livewell. Is this a bilge pump also? and how does the livewell work? I am currently redoing the Deck so I have not had it into the water yet.
