Re: How do these come off?
Good Morning,
Thanks for the thread, but I really need to know how to remove these cushions. Yes, I believe they are plywood backing with vinyl covering. I am going to try to attach a pricture. I can not get behind the fiberglass to see if there are srews/bolts. There isn't any room to get between the hull and inside wall. I hope they didn't install these before they bonded the hull and inside shell of the boat. Please see what you think.
Marty
Great> I took a picture, figured out how to attach it, but the forum says the "file is too large". bummer.
Regarding photo sizes, here is a little tip:
Just open microsoft paint, go to resize/skew, then at resize change the percentage.
The following:
If near 1024x768 resolution jpeg photo, you should not need to do any file converting.
If near 2048x1536 resolution jpeg photo, resize it to 50% on horizontal and vertical.
if near 3000x2000 resolution or higher jpeg photo, reduce it to only 25% of original size for horizontal and vertical.
Now, regarding your seat cushion bolts holding your upholstery to your bow in front of your windshield, I suspect them are in the hard to reach cavity area between the console portion and whatever butts up against it. Glove compartment for passengers, instrument dash for the driver.
Take a flashlight, get under the consoles of driver side and passenger side and look for a cavity opening where the wall is of the bow section meets the consoles. It's a good bet that you'll find bolts sticking through, that which is most likely holding your upholstery.
