How do yo utest withOut controls?
Challenger84
I'm gonna to be picking up an outboard motor and would like to know how to test it without the controls?
The ob is a 70hp Johnson if that helps.
I will bring a long a fuel tank and a battery and my tools.
Can I use jumper cables to spin the starter and do a compression test that way?
What else should I look for.
Thanks
lindy46
Re: How do yo utest withOut controls?
I usually bring a battery, jumpers, a compression tester and tool box. I'm not too concerned about starting the motor, as long as it has good compression. Also check the L/U oil for water intrusion. I ALWAYS assume the motor will need new points/coils/condensers, a new impeller and a carb rebuild. So the price I'm willing to pay will take into account those items. If I take it home and find new coils, etc. I consider it a bonus.
bob johnson
jumpers MAY work....Id get a long battery cable and crimp on some ring teminals and bolt up the battery connection right....
you only need two cables maybe 6-8 feet long and four terminals
they dont have to be as heavy duty as normally used , because they are just test cables.
the guy doesnt have a control with the motor???
if you cant hear it run, just go ahead and assume it will need a carb rebuild...and then check for spark and compression and looks for neglect and or corrosion
and look for replaced parts, gasket sealer excess is a clue...
good luck
bob
Challenger84
Thanks guys!
I'll look at all those things.
I really want to make sure it has compression.
As for the rest, seller said that the impeller was changed.
I will ask for some paper work on that claim.
