How do you check tachometer accuracy?
skyking897
Well the title about says it all. If my tach is correct, I'm way underpropped. Let me back up and start over. I bought this boat last fall and everything was ok on the test drive and still is except the tach ( I think). At WOT the tach is reading 5500RPM today but the engine didn't sound like it was screaming. Performance is as I remembered it... except the 5500RPM. How do I go about checking its accuracy?
1986 Sylvan Offshore 22
140 Mercruiser/Alpha
Michigan Prop 14 3/4" X 15P
sschefer
Re: How do you check tachometer accuracy?
Borrow a timing light with a built in tach. They're usually pretty accurate.
mcastles
Laser tach. I found my boat tach was 300 rpm off when trying to re-prop. GPS speed and accurate rpm's at WOT are critical for proper prop selection
Chris1956
I would think your tach is way off. If that 4 banger was running at 5500 RPM, you would know it, and likely see pieces flying about.
I would think most any dwell tach would work on that motor. It is likely to be 1500 RPM off or so....
skyking897
Thanks for the info, I'll look into a dwell tach meter and check it against the in dash tach.
Mischief Managed
Smack the tach. while it's reading high. Faria tachs are notorious for reading high now and then.
