how do you clean spider poop off seats?
lakegeorge
I use Fantastic and it does a great job, however there is still a minute brown spot where it was cleaned that Fantastic won't get out. Does anyone have a cleaner that removes the brown shadow that is left after the spider poop is removed?
Woodyq
Re: how do you clean spider poop off seats?
I bought a product "Davis FSR" from West Marine ad it is great, has worked on every spot where I have tried it. It is a blue gel and is probably commonly available.
26aftcab454
Simple Green works great-let it soak in a minute or two then wipe up
642mx
Nothing works better than a Mr Clean Magic Eraser. ;)
nitsuj
Just when you think you've heard of every problem you can have with a boat....
Spider poop....
FSTHUH
Magic eraser or I always use 303.. Best product ever and can be found at your local boat place...this will get it off for sure
37pro
yacht Brite serious marine cleaner has taken anything I have come across on the vinyl. Nail polish was my worst. It does not have that smell that simple green has. I follow the serious marine cleaner with 303 vinyl uv protectant. The 303 product also helps repel stains.
I have not tried the magic eraser on the boat yet but I have used it at home and it is great at removing marks on painted walls.
Good luck, Eric
ky gravy
Simple green has always worked for me... for really tough spots, I use Zing which is hydrocloric acid in a bottle.
krakatoa
Spider poop....
jajajajaja you`re right I never heard about that!:p Spider Poop??? CMON!
Try "Goo Off" can buy it @ Home depot...
Chinewalker
Spray "9" every time. I keep a bottle in each boat...
aspeck
I have to agree ... we use them for about everything on the boat, stubborn scuff marks, stains, you name it, they clean it, and with very little water use.
