How do you do a pressure test of lower unit
Stingray1961
I have a 1993 4.3 how to you do a pressure - vacum test. Specifically what hole, the drain plug
starsnstripers
Re: How do you do a pressure test of lower unit
Specifically, what drive do you have?
starsnstripers
Also if you go to the stickys "adults only" section on this outdrive section at the top of this forum you can get your specific manual that tells you everything, including pressure testing.
backyard mechanic
Pressure and vacuum testing requires a tool to do so. It doesn't matter which hole you put the tester in. If your upper and lower units are separate like on an old outdrive do them both separately.
