Re: How do you run a stern drive out of water
NO, not the same way. On the stringer drives the water pickup is located right above the prop on the underside of the cavitation plate, right behind the rudder tab. You can't put muffs on it. There is a hose flush adapter that goes into on of the pivot caps. IIRC it was an option at the time and not all drives had them. The port cap is shown in this pic:
Mine is a 1975 and came with one on the starboard side. If you don't have one, you can get a drum deep enough to submerge the leg and run the hose into it.
Welcome to iboats and the White Anchor club! (poor soul.....)
