How do you test a lower unit for leaks.
Chris1956
If you have a gear oil pump, use the hose on a bicycle pump to add a few PSI to the gearcase and listen/watch for leaks.
if you don't have a gear oil pump, I recommend you get one. It makes adding gear oil much easier than squeezing the silly tubes.
909
Thanks for the idea Chris.
Don't have one yet (only a compression tester) , but will start looking.
I was thinking of using the air compressor in my trunk (for tires) and just spray down the lower unit with soapy water to watch for bubbles.
Using a compressor is an absolute mistake.-----I use a bicycle pump.-----Gives you proper control of pressure!
tphoyt
I use a brake bleeder/ vacuum gauge and check with both pressure and vacuum. It is possible for a seal to leak in one direction and not the other. Im happy with 10 psi. And I agreed with Racer on the using a compressor. It only take a split second to blow the seal.
Crosbyman
above suggested Danbar video pressure tester works great and not to expensive.
I tested both pressure and vacum on my 75 ETEC GC and small engines from 1950-60s trick is to find the GC fitting to fit the hose and GC
I used this one...comes with the proper adapters
Not hard to make an adapter.----Thread in many domestic gearcases is 3/8--NC ----Piece of 3/8- NC bolt with 1/8th hole.----Brass tee ( modified ? ) for a gauge and shreader valve.---Use JB weld to glue pieces into the brass tee.----Not hard to make something that will work. ----Made my own adapter 40 years ago.
I use my mityvac 8500. it can switch between pressure and vacuum.
Volvo gear boxes have a spec for both pressure and vacuum testing
I believe Merc only has a pressure spec
the kit comes with adapters for most anything:
  • pressure bleeding your brakes
  • pressure testing a cooling system
  • I use the adapter off the gear oil pump to pressure test the gear cases.
