nola mike
- Apr 22, 2009
- 5,695
Having intermittent problems with my fuel gauge--it likes to read full all the time. I'm trying to troubleshoot the problem, but am not sure how exactly the system works.
1. I assume that the sender acts as a resistor. So an ohm meter between the sender post and ground should vary depending on the float level in the tank (anyone know the specs?)
2. When the power's on, I get voltage in the S wire; currently about 3.5v. The gauge has a ground, and a 12v hot wire in addition to the S.
So, I would think that I'm sending 12v to the sender wire, and the gauge is acting as a voltmeter, measuring V between the S wire and the gauge's ground. Is this correct? Here's a pic of what my simple mind thinks is going on.
