How durable are Tyvek Jumpsuits.
Boomyal
I may bid on these suits:<br /><br /> http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=3877942079&ssPageName=STRK:MEWA:IT <br /><br />Does anyone know how rugged they are? and if these are a good price? 25 for 45.00 shipped. That's less than $2 a suit.<br /><br />I did look out on the net and these seem a whole lot cheaper than than every other vendor I've seem.<br /><br />Even though I do not have a motor for my boat, I must finish the floor and I figure I will have to belt sand it smooth before I apply the Nautolex flooring. Yuck!
Dunaruna
Re: How durable are Tyvek Jumpsuits.
I have used dupont disposable coveralls in the past but I can't remember if they were tyvek. They cost me about AU$10.00 each (about US$7.00). That makes $45.00 for 25 pretty damn cheap. <br /><br />They did the job boom but you've got to be careful, they are thin.<br /><br />Aldo
gspig
Depends on how rough you are on the suit. I use a tyvek suit for a clean room set-up. I can typically use the same suit for a month.
Boomyal
Originally posted by gspig:<br /> Depends on how rough you are on the suit.
Well for starters, gspig, how about crawling around on your hands and knees, inside the boat, wielding a belt sander.<br /><br />Aldo, these are made by Dupont.
Dunaruna
Yeah I know but I think dupont have different types of disposables, I don't know if I used tyvek or not. The advertising spiel says that the tyvek is good for radiation :cool: Must be good quality!!<br /><br />Aldo
heyttown
depends on the fit....I put a set on,bent over to tie my shoes and ripped the a$$end right away.....<br />If they are sized right, they will do you pretty good.
Boomyal
Originally posted by heyttown:<br /> depends on the fit....I put a set on,bent over to tie my shoes and ripped the a$$end right away.....<br />If they are sized right, they will do you pretty good.
One of the vendors had a sizing chart. They showed extra large for my height and weight. That's what I got.<br /><br />I probably now own a lifetime supply of suits but for less than $2 each maybe I'll find new uses for them.
Dunaruna
Hey boom, you posted a pic a while back of a thin bloke on the front of a housboat, wasn't that you? Didn't look like an XL type of guy in the picture :p <br /><br />Aldo
KRS
Banned
We use them in "the service". I use them at home. Get them large so you have room to move. Pricing differences can also account for booties, hoods, etc.<br /><br />Just put some knee pads on OVER the tyvek suit and you'll do fine.<br /><br />Good price too.
Boomyal
Originally posted by Dunaruna:<br /> Hey boom, you posted a pic a while back of a thin bloke on the front of a housboat, wasn't that you? Didn't look like an XL type of guy in the picture :p <br /><br />Aldo
I didn't know they had elephants in Australia! :p <br /><br />It's the long legs that do it Aldo. That picture was taken in 1988. I've been up but have come back down to within 10lbs of that picture. But like azfyrfyter63 says, get 'em large.
jsfinn
Hey Boom -<br /><br />I picked up one of these a while ago at Home Depot to do some work in the attic. It kept me from getting covered in insulation which was nice, except I split the backside out of it working my way back through a tight area.<br /><br />Not sure if it's exactly the same as what you're getting, but probably close. They are good and make working a lot more comfortable - just take it easy on 'em.
gewf631
That's a pretty good price.<br /><br />I work in the Purchasing department for a large healthcare system, and with our volume and group discounts, we pay only slightly less.<br /><br />Ditto to what others have said about sizing - better to have 'em larger than smaller. I see you're up North, so this might not be a big concern, but these things do not breathe, so it can get quite warm in there!<br /><br />If you're trying to protect yourself from some nasty stuff, wear gloves and tape the joints with the handyman's secret weapon (duct tape). We use these suits in our decontamination areas, so they're built to take some abuse.
fixin
Hi Boom,<br />I have worked haz.mat.removal(on and off)for 7 years.<br />The suits are made out of paper,and are for a one time use.It doesn't take much to rip them.I'd spent my money on a couple cheap pair of ****ies.
If Nothing Else,.............. They make a Great Snow Camo Suit........... :D ;)
KaGee
Hey, I hear Spinner is the expert on body suits... ask him.<br /><br /> :D
LubeDude
Hey Bommyal, where is the shipping label? :confused:
Boomyal
Originally posted by LubeDude:<br /> Hey Boomyal, where is the shipping label? :confused:
Check your email LD! It's a commin'. <br /><br />Ya need any disposable jumpsuits? I'd send you a couple.
deputydawg
I use a similar jumpsuit made by this company for hazardous materials work ie. meth lab cleanup. They are fairly durable and work well. They are disposable, so easy cleanup. If they do tear or whatever, you can just get a new one.<br />I used to carry one with me in my personal cars. If I was dressed up going someplace and had trouble, I could slip one on and do the fix without getting dirty. They are handy for a lot of little jobs. <br />When we use them for official disposal work, we use duct tape on the cuffs and pant legs. We also duct tape loose around the knees to protect from rupture. They are paper but they have a stronger fiber type makeup that makes them a little stronger. Kind of like a hospital gown. It will be good for fiberglass and sanding type work you described. Problem, is working fiberglass, the fibers stick in the paper and can rub off onto skin. It is a good deal from where I sit.
2kflhr
I work in a nuclear plant and we use them a great deal. One trick to use if you are bending over frequently is to pull up on them in the waist until the crotch in the suit meets the crotch in your pants, run some tape, belt, rope or something to keep them up. They tear rather easily.
Dunaruna
Originally posted by 2kflhr:<br /> I work in a nuclear plant and we use them a great deal......... They tear rather easily.
Anyone else see a problem with that quote? :eek: :eek: :eek: <br /><br />Aldo
