Georgesalmon
- Apr 14, 2012
- 1,793
I have a 20' 1972 fibercraft with a 1979 1/2 115hp inline 6 merc. I rebuilt the carbs, fuel pump all new fuel hoses, linc and sync (all with help on this site) and now the engine runs great. Boat was also restored this winter, new stringers, floor, transom, dash's, carpet, gauges, wiring, seats, everything like new now. I added a lot of weight with 4 elect downriggers, 8 - 12 lb balls on board, 9.9 merc prokicker, another battery, 150qt cooler, and fishing gear plus all the normal boat stuff. I had myself and one more on board, will probably fish with three or four. I think the boat originally weighed about 2300lbs, now probably closer to 2800-3000.
The boat came with two props, a SS 19p and an AL 17p. At WOT I get 4800rpm and 36mph with the 19. I'm sure that the PO probably did OK with the 19p prop because of much less weight. I know I need to get down in pitch to bring the rpm up to 5000-5500. I seem to remember that each 2" in pitch changes about 200 rpm. I don't think the 17p will be enough to get me into the manufactures range so I'm not going to waste the gas and try that though I prob should.
So,,,,,,,Any ideas out there? Go to 4 blade, drop to a 15p. Don't know much about 4 blade or how to figure pitch on them compared to three blade.
I'm a Lake Michigan fisherman and will make one run out and one run back usually average 5-18 miles each way. Looking for short bursts of speed and than the trolling motor for several hours.
