how fast do you think it will go?
mphy98
I will be getting the 135hp on her soon. Still a long way off from liquid water here yet. So it is a 19' superfisherman 1991 with a 135 going on her. I believe the boat weighs 1100 pounds plus motor of 365lbs? I was just wondering what kind of speed it will do.
SparkieBoat
Re: how fast do you think it will go?
that is a light boat...what hull type/style is it?? right off hand I am going to guess about 35-37 MPH loaded..you might hit 40-42 empty..make sure it is propped correctly..should be at around 5800 RPMs at WOT
boatguy94
My 16' with a 85hp did 38mph on GPS, but that was with low fuel and a loaded boat, and water logged foam. I think your boat will be more around 40ish, but may be faster. I have no idea what I'm talking about though :facepalm: there are other's that could give you a better idea.
djpeters
My 22' SuperSport V5 with a 140 Evinrude will do 35mph (GPS). RPM's were at 5500, where they should be. You should get a little better than that I would think. 40 mph or better is probably not out of the question for yours.
SparkieBoat
I have a 17' bass boat with a 110 HP..it will hit 40 MPH loaded with your boat being 2 foot longer and 25 more horses..I figure you will turn out about the same..hull condition can have a lot to do with it..
FJ_Russo
http://continuouswave.com/cgi-bin/crouchcalc.pl
Here is a link to an online speed calculator, I have heard from some people that it is pretty much on the mark. I havent had a chance to compare it to the new boat yet water is still a little hard for that right now.
ezmobee
My guess, 40-45MPH.
zigzag
i get 28-30 mph in my 18 holiday with 70 hp
i bet you're looking at 45
LastDollar
I have a 135 O/B on mine I have been clocked at 42mph. The flat bottom helps with speed but hard on the but!
Pugetsound
Hey 98 any thing above 35 uses to much Gas. Prob close to 42-48 but at that speed carry a extra fuel tank or two. LOL Pugetsound
