how fast does your capri go?
not enuf toys
i know, not very important, more important is hole shot, low plane and crusing speed... but just for fun "how fast does she run???" :)
RGrew176
Re: how fast does your capri go?
Depends on which Capri you have. I previously owned a 1995 2052 Capri with a 4.3LX for power. According to my GPS on a good day I could hit 57 MPH.
RGrew176
57 with a 4.3? thats impressive!
I will admit I was extremely surprised at that.
This was before Selective Availability was turned off in July 2000. The accuracy of GPS could have been affected by that.
wingmastr23
Have a 1996 - 1954 with a 3.0l - It will run between 38-40.
dragginanchor
I have a 1989 1750 (bowrider) Capri with a 2.3L.
With a 19p turning point hustler, it went 43 MPH GPS last summer. And surprisingly the speedometer isn't off by much..
Gonna try a 17p next summer, as the RPM's were at the low end of the operating range.
MAXXIE
I've got an 85hp O/B & I think I remember 37/40mph on GPS, wish I had I/O like you guy's.
4runneradam
38mph according to GPS and speedo. 85 capri 85 force
steveclv
1984 Capri 1900 with Chrysler 125 and standard 13*19C prop - 38mph GPS @ 4200rpm - looking for why the rpm is so low so maybe a little more to go - maybe just break 40?
Tried looking for test results from when it was new but can't find anything yet.
oldjeep
2005 195 Classic (3.0L), goes just over 40
jkust
84 Capri 1600 with 85 horse can break low 40's on gps and speedo with the right prop. Owned it since new. No tachometer on it but it weights only 1050lbs. Maxxie, on an old boat like my 84 and your 85, I'd take an OB all day. My Chaparral with an I/O has cost me a lot in preventative alone over the years compared to my OB which has cost three spark plugs since new.
wanttofly
1990 Capri 2150 with a 5.7 and 19P prop, I am right around 40.
Jasen
'96 2050LS Bowrider, 5.7 I/O, converted to 4bbl, 21 SS prop, I have hit 52 GPS, it has more in it if I were more of a speed demon.
mc66
1990 18 ft bowrider 90hp johnson 39mph four people about 400lbs plus gear two adults two children
Jeronimus
Tried it this weekend: My dad's bayliner 1850 from 1992 with the 3.0L MCM Mercruiser and Hifly 5 blade prop.
Topped it with my GPS at about 80 km/h (= 50 mph?)
gstrom11
1990 Capri with a 87 Yamaha 90hp tops out at 40mph.
Chief2302
1987 Capri 19ft Bowrider with 5.0 tops out at around 55 with3 people
Domani
1987 Capri 1750 5.0 aq270 21p @ 58mph.
But only on glass. Had it for 2 weeks and need to replace plugs, clean carb, and put some seafoam in. If I try to give it any more it wants to bog.
corey4631
1999 Capri 1850 LS with a 4.3L V6. I had a 3 blade 21p prop and it would run 53 at about 5000 rpm's. I have since switched to a 4 blade 19p prop and it plains out ALOT faster and I get about 47 at 5200 rpm's.
