How good is Mercruiser`s V8 DIESEL Engine`s
kire
Hi
I am form Norway and we have ? Sea Ray 290 Sundancer. It`s our firs sommer with this boat and we like it very mutch.
Becouse of the price of gasoline in Norway we wonder too change the engine in it. Today we have a Mercruiser 7,4, 454 big block and with new long block that only had 50 our.
We wonder hove good is Mercruiser`s V8 diesel engine`s.
Is it anybody that now`s what price it is in USA at a new engine komplete??
jerryjerry05
Re: How good is Mercruiser`s V8 DIESEL Engine`s
Mercruiser diesels are excelent.For a price contact any dealer on line.They would be happy to give you the business.J
JVDJVD
I am looking at the Mercruiser website now, and I don't see any V8 diesel options. There are, however, three outfits in the USA that marinize the GM 6.5 L V8 diesel. Best is Penninsular Diesel, in Michigan. They get 300 plus HP out of a turbocharged version. Also an outfit in Stillwater, Oklahoma, that puts a belt driven supercharger on that same engine with similar performance but slightly easier installation without the clearance problems characteristic of the rear mounted turbo engines. Also International Diesel Ltd., of Ronkonkoma,(Long Island), NY. They make a turbo charged version of the 6.5L diesel @ around 300 HP. International says they are working on a marinization of the 6.6 L GM Duramax engine, but I haven't seen anything in production yet. I put one of these 6.5L V8 diesels from International in my 1987 Bayliner 28 foot Flying bridge. It was a lot of work, but performance seems good. Right now I am having trouble with the Bravo 3 outdrive, so have not had a chance for any sea trials or fuel consumption tests. The Achilles Heel of these 6.5 L GM diesels is overheating. One serious overheating can put cracks across the valve seats, leading to much lower compression and ultimately to burned valves, and also they tend to crack or warp the center main bearing saddle in the block leading to lower end failure.
Do you have the room for a 6 cylinder Volvo diesel setup in your boat? Probably more reliable, but more expensive than Mercruiser(?) Mercruiser 6 cylinder diesels are based on two engines, one being the Cummins 5.9 L which has a good record in Dodge pickup trucks, and the other is a 4.2 L Cummins based on an Italian block by VM Motori.
TilliamWe
Banned
I also noticed that currently Cummins/Mercruiser does not offer a V8. The 5.9 I6 they do offer is an excellent engine, and has been used in Dodge pickups for years.
bigbrownbuku
Master Chief Petty Officer
its way too long for that bilge, you can buy a whole pile of gas for the money you will be out of pocket switching to a diesel.
skargo
Banned
Yep, and a whole lot heavier. Crated shipping weight for a Cummins 5.9 is 1350 lbs!
