how high is that motor?
fishhair
hey guys
i'm running a '77 johnson 70 hp on a 15.5' skeeter, with a CNC power t/t.
how high should i set the motor on the jack?
JB
Re: how high is that motor?
Start with the av plate about 1" above the bottom of the boat. Adjust as required
roscoe
that cnc unit will give you 6" of setback, so you can go a little higher.
The key is to have the anti-ventilation plate at or above the water line when the boat is on plane
