How hot?
suparslinc
87 305 mercruiser. Just got some issues resolved today, hooked up the hose and started it up. I wanted to let it reach full operating temperature so I had an idea where that was, well when the gauge got up to ~200F I chickened out and shut her down. That seems like it's getting a little on the hot side to me.
I believe the impeller was working because I had water pouring out the petcocks in the bottom of the block at first. But I saw that immediately, shut it down and closed them. So how hot am I supposed to be running?
Re: How hot?
Ayuh,....
About 160?......
I'd start with the Impeller.....
suparslinc
Re: How hot?
Know whats funny? After screwing around with it for a couple more hours with same results, I gave it a little throttle. The temp gauge dropped like a rock to ~175. I wonder if the impeller wasn't spinning fast enough at idle to pull fresh water.
Don S
Re: How hot?
It's a rubber impeller and the vanes are probably bent over due to lack of being replaced when they should have been. Evey other year is recommended time for impeller replacement.
suparslinc
Re: How hot?
I've heard that. Can't remember if the guy who sold it to me said they were replaced or not; looked at a couple boats and what I was told runs together. I'll have to do that this summer don't want to burn the engine up.
