How I can repair My new air conditioner that drip water into my room?
any
I have a new TADIRAN air conditioner (one year) in my room, the size of my room is 12 meters.
Yesterday when I operate on my air conditioner the air conditioner start to drip water in my room.
The water drops fall down from the corner of the rectangle that output the cold air
Do you know what break down in the air conditioner?
How I can repair this?
saumon
Re: How I can repair My new air conditioner that drip water into my room?
ehh, welcome here first time poster. It's a boating forum you know?
Bob_VT
Not a boat question. Moving to Non Boating forum.
royal0014
Master Chief Petty Officer
Well, he did post in the 'non-boating technical topics'.....
Welcome Aboard :cool:
Tubingluvr
Either there is not enough slope on the ac unit or the drain is plugged....unit should have good slope toward the outside....if the drain is plugged and you cant get it unplugged just drill a hole at the back of the bottom of unit
BuzzStPoint
Most new AC's dont have a "Drain" anymore. They disperse the water by evaporation. it's picked up by the fan, slung and gets blown into the condenser, then evaporates. This also helps the condenser cool down.
However, I think Tubing is on the right track here. Most people shove in the window AC and fire it up. It should be level to tilting "outside" this way the water won't drip inside.
hrdwrkingacguy
lol
This unit is a ductless mini split and has a drain, a drain pan, and possibly a pump depending on the application...Drain is either clogged or the pump is bad, or the outlet of the pump is clogged...:eek:
BuzzStPoint
lol
By that, I assume we are not talking about a window style AC..
My Mistake.
