Re: How is the length of a boat determined?
Some/most manufacturers have used the measurements from the "usable" part of the boat (hull length). This would be, in my specific example, from the pointed portion of the bow to the transom. Hence my Carver 374 is a 37' boat and the "4" is part of the model number (convertible), whereas another number (372 for example) might mean a 37' hull with an express-style cap.
I haven't seen any boat where the numbers indicated feet & inches (244=24' 4"). Most often, the model are hull length and design.
However, measuring my boat from the tip of the bow pulpit to the rear of the swim platform gives me a 40' LOA. I can use this measurement to impress girls...much like adding inches to other things to impress girls
Luckily, my marina charges off of the listed hull length, thereby saving me roughly $25 per month.
If you want an accurate length of your boat, run a tape down the centerline from the tip of the hull to the transom (then add 2' to impress the girls
