How long do I run blower?
jwharan
I always run the blower on my 19' Runabout for about 2-3 min before starting. Do i need to leave the blower running all the time, or only when starting the boat? What about when idling?
tommays
Re: How long do I run blower?
if you go buy the book most boats recomend useing it when your below planeing speeds<br /><br /><br />tommays
Chris1956
jw, I also give the blower outlet the sniff test, while the blower is running, to make sure there are no fumes.
Scaaty
Best to give the motor a good lookover as much as possible, paying attention to the complete fuel system connections. If you do little off plane running, only on sitting and restart. Lots of trolling , etc, run it. The air just simply needs replacing if nothing more than to dump the heat, besides the trace amount of fuel vapor, which can really wreck yer day.
KaGee
I leave it running. Cheap insurance if you ask me.
Wellcraft260
Is there a such thing as a fume detector for combustable gases? It would sure be nice to have to help eliminate the human error aspect of fume evacuation.
Trent
Gas fume alarm.....<br /><br />
randyo
Any reason to not constantly run it? On my boat, its not very loud...
sea wolf
Originally posted by Trent:<br /> Gas fume alarm.....<br /><br />
Are you the same Trent that used to post on another boating forum whose name escapes me. I think the moderators name was Bo. Great forum.
Lou C
I have heard that some blowers are not rated for continuous use, but I ususally leave mine on all the time so as not to forget to run it at slower speeds. Only time I turn it off is when at the gas dock gassing up. <br />I also sniff the air the blower is exhausting in addition to smelling the engine compartment.
