how many amps does the starter draw?
comet424
hi I deciding to re wire my boat to put the batteries at the front of the boat since they be out of the way instead of battery boxes at the back, but I wanted to know how many amps does the starter use as I was going to use 4 gauge booster cable wire and just cut it up
this is for that 1978 115 hp engine I working on
tpenfield
217 amps, but that is just an estimate. It is a lot, instantaneously, Thicker cables are better. There are some guidelines that you can google to right-size the cables based on load and length.
tpenfield
Edit: may be more in the 150 amp range for your outboard. Was thinking and I/O starter. Still quite a bit though.
tpenfield
oh ok
ya I following this guide
http://www.offroaders.com/tech/12-volt-wire-gauge-amps.htm
just wasn't sure
so roughly 20 feet
but then again its only instant for a few seconds burst really its not a constantly running
If you are undersized on the wiring, it will eventually 'cook' the wire, eventhough it is only a few second burst, and the worst of the current is while the starter motor is spinning up to speed after it engages, which is fractions of a second.
Based on the chart, 4 GA looks OK.
