How many amps?
pike hunter
T 9.9 EXHS 1994. Would like to know how many amps the alternator is producing.<br /><br />Want to use it as a kicker; will run my auto-pilot (Raymarine), downriggers and Sonar-gps.<br /><br />Do you think it will be sufficient to keep my batteries charged at trolling speed?
john-206
Re: How many amps?
Got a 9.9 myself. They produce a maximum of 10 amps but the only way you will know for sure what it is outputting is to fit an ampmeter.
WillyBWright
Re: How many amps?
You'll need RPMs to get decent output. If you're going to be trolling at or just above idle, it won't put out much.
31900
Re: How many amps?
I agree that at trolling speed you may not have enough to maintain full charge but there may just be enough to get you through a few hours without taking too much out (depending on the current draw). If more than say 5 amps, don't do it. Then recharge when you dock.
pike hunter
Re: How many amps?
Thanks for the answers. I will start the main engine time to time just to be on the safe side.
31900
Re: How many amps?
Good idea! Try it. Time will tell how far you can go safely. An ammeter would be a great addition to your instuments.
