how many liters?
hitace
how would you tell how many liters a outboard has?
jimmbo
Re: how many liters?
check the specs, in the owners manual, service manual, or the sales brouchure.
100 cubic inches is a approx 1.6 litre
Silvertip
1 liter = 1000 cc = 61 cubic inches. Geez I wish we would have completed the switch to the metric system. It's just too darn simple.
jtexas
"The metric system never really caught on in the states. Unless you count the increasing popularity of the nine millimeter bullet."
--Dave Barry
hitace
do you think it would be in the repair manual?i tryed to get a sales brouchure fom the dealer when i bought the boat but he only could get a 2003 sales brouchure and i bought a 2007 boat with a 2000 johnson both were never used and im sure the 2003 BRP johnson is not the same as a 2000 OMC johnson.
CATransplant
If you give us the model number of your outboard, I'm sure someone will be able to tell you its displacement. Without knowing which outboard it is, it's not all that easy to guess.
It would be in the service manual for that engine, but there's probably an online source for the info, too.
I'm sure if you called your dealer and gave them the model number, they'd be able to tell you too.
hitace
also the numbers and letters dint match up in the service manual ???? and I'm sure it is the right one and i would also like to know if it is a fresh or salt water outboard.the dealer did not have any info on it he has Ben selling nothing but yamies since 2001.
Silvertip
It sure would help if you told us what engine you have. I have a 2005 Johnson brochure and at that time the largest two-stroke listed was a 175 HP. It's a 60 degree V6 with 158 cubic inches or 2589 cc or 2.589 liters (see how easy that conversion was)? The 90 and 115 were V4's with 105.4 cubic inches or 1726 cc or 1.726 liters. The 40 and 50 were two cylinder engines with 45 cubic inches or 737 cc or 0.737 liters. I'm not positive, but I don't think those displacements changed between 2000 and 2005. In fact, I doubt very much except quality changed (for the better) in those years.
hitace
its a 2000 carb 2 stroke Johnson ocean pro and theres probably a pretty good chance there is a difference since yours was made by BRP and myn made my OMC but you might be right they may be the same
Dhadley
It's a 2001 150 hp, 60 degree V6. Silvertip nailed it from there. It's "commonly" refered to as a 2.6 liter but is really a 2.589 liter.
hitace
this is a slat water outboard right?
hitace
i see fresh water ocean pros on ebay thats why i asked and my dealer dont nothing about it.
CATransplant
If your dealer doesn't know that an "Ocean Pro" motor is OK in saltwater, then I'd go hunting for a different dealer, I think.
Ebay sellers often indicate that a particular outboard has only been used in fresh water. It's an important bit of information, but it doesn't mean that that model of outboard can't be used in salt water.
Seriously, though...start hunting for a new dealer.
