how many spray cans do I need to paint an outdrive?
dannieboiz
Does anyone know how many cans of spray cans to paint an OMC outdrive from top to bottom?
Gary H NC
Re: how many spray cans do I need to paint an outdrive?
Depends, If you sand and prep very well and want a good paint job then at least 3 cans.
Any bare metal needs a very light coat of etching primer before paint.
I use the Moeller brand engine paints.They have the factory matched colors.
D
DJ
Guest
Yes it takes exactly ONE MORE than you have.:p
Two should be plenty.
oops!
baaaa haaaa haaaaa/////
DJ.....aint that the truth ! :D
i do mercs with one can.
do it to every boat that the drive comes off.
costs me hardly anything......and the owner is blown away every time
dannieboiz
Should I do another coat of clear over or just 2 coats is good enough?
oops!
if you are happy with the results of the second coat....why bother?....
if you get a scratch.....you can just touch it up....if you clear it.....that is another step
dannieboiz
that would work for me good tip on the clear. I like less work with good results so 2 coats is fine for me. :)
