Re: How much foam?
hello, <br /> can i pick a little about "foam" use, not for boats . <br /><br /> got a hot tub cover and the foam core weighs a ton. a new cover is $400. I figure most of that is in tailoring the cover. these things seem to go bad every 3 years. <br /> Can i use this foam you speak of to make a new insert. 60" round, 3 inches at the diameter tappered to 2inches at the circumference. <br /> i figure it might take a little to make a form but the repetition of buying a new cover bites. <br /><br />any imput, thanks
