How much fuel do you guys head out with?
CaptainYARRR
I normally run about half a tank. I decided to see how much fuel she could hold and I filled her up. I was convinced I left the drain plug out when I left the dock it felt so heavy. It makes sense since fuel is very heavy, but it was extremely noticeable. I have a EFI V8 pushing my 22' Monterey, so lack of torque isn't an issue.
I think half of a tank is the way to go for me.
What's your guys' thoughts?
mphy98
Re: How much fuel do you guys head out with?
I always head out full, just in case. We fish up in Canada so we never know where we might end up ont the lake. It is 60 miles long so I want as much fuel as possible.
Thad
I always top off the tank. Just an old habit I suppose.
My boat holds 50 gal of fuel and I avg. 19 gal of useage a day.
You know the fuel is there for sure. I loose 5-6 mph with a full tank, but have never felt it so heavy that I was worried.
Now, I get another couple, their kids, and all of that extra gear in her, I change my prop out to a lower pitch to compensate.
That may be what you are feeling. For instance, I run a 25p with just my family and gear. Depending on who else will be going I will drop to a 23p or a 21p to push the weight.
Hope that helps ya out a little.
Thad
Also, my fuel useage goes up a lot, so I need that full tank.
BamaAlum97
I rarely will head out with less than half a tank. I typically go ahead and fill up on my way out. The lake I boat at isn't really that big, I just prefer to be more safe than sorry...
Nandy
95 percent of the time I go full tanks. In days where i know all we are going to do is swim I could then go with half a tank, but never less than that.
ThePostMan
Seems like it depends on where you boat. Most of my boating is done on the Ohio River. . .so I almost always top off the tank. I could spend the day puttering around in my local pool, or zip through a lock or two and head downtown, change rivers, visit other states. Nice to have the option!
AZSenza
Full Tank, better to have it and not need it that not have it and need it!!!Kind of like something else I always have...
dingbat
I normally leave the aux tank empty but refill the main tank (92 gallons) when it gets down to half a tank.
If heading offshore fishing or fishing a 2-3 day tournament I?ll fill the auxiliary tank (47 gallons) as well. The extra 1100 lbs slows me down a bit but I?ll have fuel if I need it.
lime4x4
when we go to the Chesapeake bay i always top off the 100 gallon fuel tank
Thajeffski
Master Chief Petty Officer
Usually about 3/4 - no sense in pushing around all the extra weight..
skargo
Banned
I boat the Chesapeake so I fill up every time. I have a 60 gallon tank.
Ayuh,... I keep both my tanks Full,... Year 'round.... No Condensation that way...
redone4x4
I have a 33 gal tank,and I top it off on the way to the lake every time. I like knowing that fuel is not an issue. 1/3 there, 1/3 back, 1/3 reserve. I usually have waaay more reserve than that though. Sometimes we go out for 2 days at a time, in which case a full tank is perfect, still have half a tank left usually.
n2ostroker
It's amazing how much you can go through i a day or 2 playing around. I fill up on the road on the way. That way I don't run out and use crappy overpriced old marina fuel. If running around I'll burn 15-20 gal/day. I don't like being towed...
jay_merrill
Full tanks, which equates to more than four hours range at a constant cruise speed. In everyday use, which doesn't involve constant cruising during the entire outing, my range is considerably more than that.
dave11
When it gets doown to 1/2, I fill it up.
109jb
I generally never run below 1/4. I don;t really have a set amount that I start with, I just judge what I will be doing and how much I need. I may lose a few knots in speed, and have a little slower time to plane, but my outboard powered boat is near the max HP so it isn't a big deal as I have plenty of performance.
