how much play acceptable on prop shaft
vanislander
how much play is acceptable on the prop shaft on a merc 30 ? right now i have .25" play with the prop removed
KenMcG
Re: how much play acceptable on prop shaft
If you mean that you can pull the prop shaft in and out a quarter inch, I think you have a broken snap ring on the inner most gear or a sheared pin that holds the gear to the shaft. I think if you try to run it, you can damage more expensive parts. I would drop the lower unit and dissassemble it.
