How much play in drive shaft/engine coupler?
MN86_4winns
I just removed the u-joints for replacement and cleaned up my drive shaft on my alpha one. I also cleaned up the engine coupler, the spline grease had hardened. After cleaning, I dry fitted the drive shaft into the coupler and I noticed quite a bit of play. The splines on the shaft don't appear to be worn. Is it common for the splines in the coupler to wear?
Gary H NC
Re: How much play in drive shaft/engine coupler?
Yes,it happens. Did the splines on the drive shaft look kind of pointed?
They do wear more than you would think.
I don't believe there should be much side to side play at all..
One cause of wear is improper drive alignment.
Zackman
The other cause of excessive spline wear is the lack of grease or the use of improper grease.... It's a tough service and is often over looked or under appreciated.
Ayuh,....... I Agree with these Guys,.....
It only takes Alittle Bit of Wear on the Shaft,+ Alittle Bit of Wear in the Coupler,......
It Adds up to Alot.....
I'm a Trolling Fisherman,.... Which is as Tough as it gets on those Splines......
My drive is showing early signs of Wear now at about 700hrs......
But, that's with Good Maintance,+ Grease......
When Both are New,....... There's Little to No play in them,.....
How Far Gone your's is, could Only be a Guess........
f_inscreenname
Replace the coupler now before it cost you another motor pull to get to that (what is now) cheap replaceable part.
