How much resin do I need?
MRS
Need to do a 6' x 5' floor section for a friend do not want him to buy more than he needs. He cannot be around fumes because of medical reasons floor was cut out so he could clean out fueltanks and change fuel lines. I have glasses small areas but nothing this size going to lay one layer of material will that be enough plus carpet will go over the floor. Thanks for any reply's.
Cadwelder
Re: How much resin do I need?
The second sticky at the top of the forum will tell you all you need to know...has all the ratios and formulas you need.
Good luck with you project.
Woodonglass
You'll need to precoat the wood with Poly and then add 1 layer of 1.5 oz CSM on the bottom layer of the wood. On the top Lay two layers of CSM and you're done. 6 yds of CSM should do it and 3 gallons of resin.
MRS
Thanks guys buying the stuff tomorrow and doing Saturday. Bruce will be a happy boater very soon.:)
oops!
cool ....woodie is correct
MRS
Thanks just to refresh myself I will precoat while stilll tacky lay csm mix and pour. Then still tacky lay csm mix and pour and should be good to go then:) Thats two layers on top. Thanks once again for the fast replys...
30yrnavy
Will it really take 3 gallons of resin? I'll be doing a 5 X 9 floor and I thought 1 1/2 gallons would be more than enough. I guess I need to rethink before I buy the resin.
74bayliner
yeah i though about that too... Resin is expensive. But its true, that fiberglass just drinks it up ... and its better this way.. for a little bit more expense your boat will last longer if fiberglass work is prepped and done properly
Woodonglass
MATERIAL.........................................GALLONS
1.5 OZ MAT = 1 gallon covers 4.2 square yds
2.0 OZ MAT = 1 gallon covers 3.4 square yds
There are about 150 ounces per gallon by weight
1.5 ounce cloth ( cloth not chopped mat)?.1 gallon wets out 40 square yards
2.5 ounce cloth?.1 gallon wets out 25 square yards
4 ounce cloth??1 gallon wets out 15 square yards
6 ounce cloth??1 gallon wets out 10 square yards
10 ounce cloth?..1 gallon wets out 6.5 square yards
18 ounce woven roving ?1 gallon wets out 4.5 square yards
24 ounce woven roving ?1 gallon wets out 3.5 square yards.
Biaxial mat 1708.????.. 1 gallon wets out 4 square yards
Please remember several things:
- these are estimates not hard and fast rules.
- if you are laminating over wood, the raw wood will soak up some resin, which is good, but you will use more resin on the first layer.
- thin resin goes farther than thick resin.
By the time you precoat the wood, allow for any waste, you're gunna be cutting it close with 3 gallons, IMHO.
JDA1975
buy a 5 gallon pail, I am not sure where you live but my fiberglass supplier sells gallons for near 50 bucks, but he sells 5 gallon pail for 115, so if ya bought 3 @ 50 your wasting 35 bucks and 2 gallon. can never have enough resin! Any left over save for your next oops moment!
MRS
Re: Update, How much resin do I need?
Thanks, for all the advice guy's did it yesterday morning everything went great. One bad spot something stuck under csm but no biggie will patch that spot late today. Bruce is a happy boater now Thanks once again....:D
