daydreamer1252
- Aug 7, 2007
- 212
About to replace the transom in an I/O (mercruiser R series drive) want to wrap glass and resin around drive cutout in the wood to seal. Wrap from material (glass) from between plywood and outer shell through hole and attach to inner surface of ply.
How much room does one have to "play" with?? Does outdrive need "all" the room to mount or will plus or minus 1/8" around the edges not affect the fit and movement needed for normal operation??
Thanks for all replies and thought.
