How much should a rebuild Cost?
cableguy277
I know this is a redundant question but I am curious as to how much it should cost to rebuild an OMC 400?(worst case scenario aside from replacement)I ask because I have a pretty good feeling I need one and am not sure what will be cheaper,rebuild or replacement.Thanks ahead of time.
man-of-war
Re: How much should a rebuild Cost?
kracker,try this.a remanufactured engine $2251.00 . I found a remanufactured 454 gen 4 long block located in Washington 1800-942-7800 .the engine is a standard /LH rotation.
Kracker is asking about his Outdrive,.........<br /><br />An OMC 400 Isn't a Motor......
KaGee
Kracker, you are looking at $800-$1500 to go through that drive. Depends what's worn out.<br /><br />Take a look HERE. The specialize in OMC Sterndrive repair.
