Re: How much water from the prop?
1974 Merc 140<br /><br />Per the manual, can't have too much hose pressure, so I open my garden hose faucet 1/2 turn. It's my own well, so that probably doesn't do you much good. With the stern drive all the way down, in neutral or gear at idle about half of the water comes out the prop. The rest comes out the bypass holes on the bottom of the gimbal housing and the small hole on the starboard side of the lower unit. With the stern drive up halfway or more, nothing comes out the prop, most comes out the bypass holes.<br /><br />With the drive down, I think you should see some out the prop, but I'm not an authority on the subject. It's possible, but probably not all that likely, that you have some blockage in the stern drive exhaust path. Have you confirmed that your exhaust shutter is in place? Mine was completely missing; I'm still not sure if the two halves blew through or are stuck in the drive somewhere.<br /><br />> I'd say it accounts for all the water going in.<br /><br />I'd certainly hope so! (Think about it for a while.)<br /><br />Steve
