how much weight can this support?
Frank Acampora
Re: how much weight can this support?
Girlfriends range from 98 pounds soaking wet to over 400-----
Frank Acampora
Tanning or fishing should be OK. Fiberglass will flex a LOT before being damaged. Remember: It is usually illegal to sit on the deck while moving at more than dead slow speed (unless it has rails).
You should check under the deck to see if there is any wood or fiberglass/foam supports. If the deck is whippy, the windshield may crack at the mounting bolts
MWG2600
push on it and see if its strong or not
ajgraz
my girlfriend was just asking me if she would be able to sit on the hood of our boat to tan or to fish. I am just not sure if is designed to hold any weight at all.
What she's really asking is, "Does this cracked fiberglass make me look fat?" :eek: :D
UncleWillie
It looks like the logistics would kill the whole idea.
Beside that the deck was not built to be walked on, it looks too small to actually lie down on.
Is that the Horn smack in the middle?
And finally just how would you get up there with the windshield in the way?
It looks like something that sound workable until you actually try it.
roscoe
Can't tell without a photo. of her :)
If in doubt, put a small wood brace under the bow.
Don't let her lean on the windshield. crack!
she is gonna get sunscreen all over.
nigels
If she's 400lbs upgrading your trim tabs aint gonna help!
Alwhite00
Master Chief Petty Officer
Tell her to be careful around that horn.
LK
r.j.dawg
Ensign
I see two cleats and a horn that look very painful if someone were to slip. :eek:
