how mutch whater i suppose to see
strocker383ca
how mutch whater i suppose to see from the bleeder at right side at full throttle on a 200 jonhson 1989
wayne h
Master Chief Petty Officer
Re: how mutch whater i suppose to see
do you mean the pee hole ??? water from the water pump ??? it should be a steady steam. if this is not what you mean please explain better
strocker383ca
yes i mean on pee hole ,just see some little drop of water at full throttle it is ok
wayne h
no thats not ok. sounds like you might need to change the water pump . how long has it been since you changed it
strocker383ca
i change it last year but i think i found the problem but not sure i'm waiting for my motor it blew up this summer.they got a little oring who goes bettween the impeller steel housing and the plastic housing and it was blow out it is possible to be my problem for whater pressure.and may that loosen water pressure can make some heating in combustion chamber and make detonation sounds
