Re: How often to change impellers
This article has some good information in it. You can anticipate earlier impeller replacment if you are running through alot of crap or sand that is going to wear the impeller out. Remember that it is rubber so it doesn't take that much to wear it out. However, if your outboard is only operating in clear fresh water, it will last a very long time. You can run for several years. I just replaced mine after 2 years and found that there was very little wear on it. I certainly didn't need to replace it, but since I had it apart... I have a Nissan 50 TLDI, and it is a simple replacement. <br /><br />I suppose cost is relative...but I have not found impellor kits to be all that expensive.
