How Reliable Are VRO Systems
biloxiriver
My nephew has bought a 1996 70 hp Evinrude that has VRO. I have heard that the VRO systems often fail and result in damage to the engine. Is this true or are the systems now reliable?? The last motor I owned with VRO was a 1989 70 hp, that the previous owner disconnected, so we just mixed oil the old fashioned way. Any thoughts out there.
walleyehed
Re: How Reliable Are VRO Systems
The 96' model should have the newest VRO system, and shouldn't cause any problems if you keep it clean and well maintained..... :)
D
DJ
Guest
The systems are only as good as the maintenance they recieve. There are hundreds of thousands of them out there that are, and have been, absolutely trouble free.<br /><br />There are really only about two things that need to be done, at least annually.<br /><br />1. Check all lines for tightness, cracks, etc.<br /><br />2. Dump the old oil. Refill and run 50:1 pre mix until you verify oil useage.
