Ok, as a follow up to a previous thread, I am now working on my audible warning system.
On the engine side, I have a water temp sensor on the port side of the engine and an oil pressure sender on the aft port side of the engine, both wired to the #4 hole on the engine harness plug.
On the boat side harness plug, there is no #4 prong to go into the hole on the engine harness side. However, there is an appropriately colored tan/blue wire that has been run up to the buzzer. The buzzer has a purple and red wire going to it as well. And it looks pretty bad!! Rusty and the like.
So first, when should this buzzer go off? My understanding is when you turn the key to run or start, and the oil pressure is low, then it will alarm. Once the engine is started and oil pressure is good, it goes silent. Then it can come on when the oil pressure drops or water temp gets too high.
How can I test the buzzer now, as well as the sensors. I'll rig a connection at the plug for the engine side to connect to the boat side.
Thanks all!!
Thanks all!!
