Re: How strong is fiberglass?
Bad idea! It's the wood under the fiberglass that holds the lag bolts. Here are, however, two SHORT TERM suggestions.<br /><br />Pull out the existing bolts, they are probably 2.5 to 3" x 7/16" unless someone has already replaced them. If they are original there is probably not much thread on them. (rusted)<br /><br />Go buy 1.5 inch longer and one size larger diameter (1/2") stainless steel bolts. Don't bother with the outboard bolts in the claw feet. You will probably have to chase the two inboard mount feet holes with a drill to slightly enlarge them. Now run your new bolts in. <br /><br />If they do not bite then you have real problems. Do not use the boat or you're liable to have an engine sitting in your rear passengers lap.<br /><br />I remind you, even if this works it is only a short term fix. You've got rot and it's not going to fix itself. Study all the projects on this forum cause you are problably going to end up an expert by the time it is all over.
