How Tight
ken52
I'm installing new thru hull fittings. Is it better to tighten snug then after bedding compound cures tighten a little more or tighten until compound pushes out from behind face and let cure?
Woodonglass
Re: How Tight
Don't CRANK it down and starve the joint of compound, but make sure it is bedded securely.
ken52
Re: How Tight
So basically tight enough to keep it from spining but don't squish out all the bedding.
