How to add fluid to trim tabs
Lancerdad34
I feel stupid asking this one guys but this is the first boat I have had with trim tabs. How do I add fluid? I took off the top and see no place to add fluid or check level as I can't see thru it.
Thanks,
Brian in MI
take screw off top of grey cover. remove grey cover, fill is under grey cover
Lancerdad34
I did take off cover but I must have missed something because I did not see where to put it in.
Brian feeling like a novice!
dingbat
You read fluid level thru the translucent tank at the botton of the unit, thus the silver full and add sticker on the front
tpenfield
Here you go . .
There is a little cap that comes off just to the side of the motors.
