I just bought this 2009 Crownline with 2007 4.3 TKS Mercruiser. Can someone explain how to adjust the idle? It runs excellent however after the engine is warmed up, it idles at 800 rpm. I want to idle it down to 700-750 because of 2 problems. 1) it grinds into gear. 2) it diesels when turning off the engine (especially after getting the engine temp up to 180 degrees from driving it fast) I have found ways from forums to get it to stop dieseling such as letting it idle for a couple minutes before shutting the engine off and putting higher octane fuel in. But I think idling down would also help. Also, I really hate hearing the gears grind and jerk into gear. I just don't know how to adjust the idle on this. Can some help please?
Thanks,
Tim
Thanks,
Tim
