Hi, i`m working on a 1996 Volvo SX Cobra single prop out drive. I took the top housing off the lower unit and found the 2 O rings - one on the oil screen hole and the other on the drive shaft bearing retainer Damaged.
The larger one was crushed flat and cut. The smaller one was probably ok but I am replacing both. Whoever worked on it before me used what looks like contact cement to seal them. When I put the new O rings in place and install the top housing onto the drive there is no place for the O ring around the retainer nut to fit into other than a large chamfer around the bore in the top housing. When I put the bolts in and torque them to spec there is a big gap between the upper and lower housings.What am I doing wrong? The service manual is not very specific about the procedure. Thanks in advance for your input.
