Cougar_15
- Aug 11, 2008
- 93
It looks like I painted myself into a corner and I'm hoping that someone out there can help me come up with a solution to my latest stumbling block. I wanted to change the seating layout in my boat so I built a bench seat to go in front of the splash well (I will be building a back rest but haven't got there yet).
The challenge I am now faced with is how to attach it to the hull. The kicker is that it needs to be able to be easily moved/detached so that there is access the area under the splash well (battery, bilge and gas tank). I have only come up with 2 ideas and I'm not sure that either one is the best answer.
My first idea was to mount the bench on top of heavy duty drawer/shelf slides such that the whole bench would pull out. My concern is that since that area will definitely get wet I don't know how well they would hold up (even if I use stainless).
My only other idea is to attach it using hinges on the bottom of the front panel such that the bench would tilt in toward the center of the boat. This is not my first choice but I know it would work...
Does anyone have any other ideas?
