How to bolt these new fenders properly to my trailer??
Darren Nemeth
Well, I my new fenders are here. Its these ones.
http://www.iboats.com/Black-Plastic...914329--**********.701510419--view_id.169917#
Can anyone show me how you have yours bolted to the trailer? Just a pix should be enough. I just need to see.
Also, more importantly, is there any important things I should know in order to have them properly and safely positioned?
Clearance from the top of the tire? and stuff like that.
Thanks in advance!
tpassmore
Re: How to bolt these new fenders properly to my trailer??
good luck, they aren't easy. but if you succeed you can write a sticky note on howTO
bruceb58
Looks like you could use a piece of 1" angle iron and extend that to the trailer and attach it to the trailer with large U-bolts. If you use that, I would cut the edges of the angle iron off at a 45 degree angle or grind it so there isn't a sharp point.
