How to buy an outdrive?
peejcj8
If I wanted to buy a new outdrive, how would I do this? While looking I see outdrive for sale, but they never contain the transom assembly or the flywheel cover etc.
I have found new uppers, new lowers and transom assemblies sold separately, but what about the flywheel covers and y pipes?
It seems some one would have complete conversion kits
Fun Times
What exactly (engine, drive, transom assembly, year, model combination) are you trying to buy?
what are we converting from and what are we converting to? this is a very important bit of information.
peejcj8
I have a 1979 5.7 mounted to a aq280 drive. I repowered 3 years ago and went with the older block motor so I could still use mechanical fuel pump, but went with Vortec heads. It only required a modified flywheel, but everything else is the same fit as the 1979. Boat is a 24ft Albemarle.
Was looking into the total price of possibly a ocean series VP or a Bravo 3. I would also look at used, but I only see the drive sections for sale when I find late model outdrives. I assume I would need to piece part the whole conversion whether I do it with new or used outdrive?
You will have to rebuild your transom to go for the old AQ drive to a newer VP or Mercruiser. There used to be an adapter/conversion transom casting, however it was about a grand
peejcj8
I assumed the economics would not be worth the effort. But I was curious about the lack of information on options to come up with a dollar amount. So if I purchased the adapter, I would then need to purchase the other items piece by piece?
Ayuh,.... That's the expensive way to do it,....
Buyin' a junk rotten busted crashed donor boat, with a runnin' driveline of yer choice is the cheaper way out, 'n ya get ALL the parts, 'n pieces,.....
Agreed Bondo, however the transom cutout for the current VP280 is just a hair smaller than the old OMC holes. So switching to anything except a VP AQ series DP290 will either require rebuilding the transom or the aformentioned no longer available adapter. If it was my boat, I would sell the 280 and find a DP290 or DPA
Ayuh,..... Understood,.... The adapters Are out there, though seem to bring 'bout a Grand,....
You can glass in the hole, 'n recut, I believe, cheaper,....
I mention the donor boat idea, as the cut-out pattern is there, as well as every piece needed for the entire driveline,.....
I can't Imagine the total tally of buyin' a complete driveline, by the piece,.....
Even used, ya spend to much, 'n find out all the things that oughta fit,... but don't,.....
