Re: how to change impeller 1998 evinrude 115
I would STRONGLY suggest that you get the OMC factory service manual (mine has the black/gold cover) published by OMC/Bombardier. Any other aftermarket manual is a poor second choice. Your dealer can get one for you, usually about $30-$50.<br /><br />One tip: if you remove the port-side mid case panel, it is much easier to do the shift linkage which is the hardest part of the whole job for me.
